brianb242 »
https://forums.nicoclub.com/brianb242-u174833.html
Wed Jul 06, 2011 9:08 am
first I'll give you guys my set up.. new water pump oem,ISIS radiator bought from raw brokerage, two 12" pusher fans no a/c condensor, no thermostat, 50/50 premix coolant, adjustable fan relay wired to run both fans when engine hits 180 degrees. I also made sure to get all the air out, opened the bleed screw on the intake let it idle filled it more, drove it checked out ok. when driving just putting around it's fine car runs normal, get on the gas to get on interstate or play around on the back roads, stop and go traffic it runs hot, basicaly anytime the turbo pushing full boost the engine climbs temp like crazy! I am starting to think maybe the car runs lean?? Im in S.C so mid day temps get above 95, I thought maybe the head gasket was blown, did a compression check all 6cyl came to 115psi, I have a service manual but it doesn't give psi it's in kg/cm squared, I don't know the formula to convert it. does 115 sound right? also at night I can drive it hard with not much of a problem but that is when it was only in the mid 60,s at night. also there is no mixture of coolant or oil in radiator or on dip stick.... high idle problem..., after adjusting the tps it's not as bad as it was but it's still about 500rpms to high, checked everything that could cause a vaccuum leak, also did a boost leak check, found nothing! not sure of other info on that to give you guys. all I can say is im pretty freakin aggrivated with this.
