wawazat8402 »
https://forums.nicoclub.com/wawazat8402-u20196.html
Tue Feb 13, 2007 8:15 pm
mine did the same thing after the greddy im install. turned out i had a huge vac leak. might want to get a bottle of soap water and spray around. to check the piping, get a boost leak tester and pressurize the pipes and spray them with the soap water and look for bubbles. to check post throttle body, pull a vac line and use it to pressurize the mani and spray the vac lines, where the throttle body seals, and where the intake mani meets the cylinder head.
