R32MS »
https://forums.nicoclub.com/r32ms-u74200.html
Wed Aug 22, 2007 6:54 pm
I wouldn't recommend just bolting a turbo on a DE engine, the compression ratio is totally different for NA and turbo RB engines, Unless you only want to run low boost levels by putting a turbo on the DE. If you try to run the higher boost levels with a bolt on Turbine you will blow the engine. I would recommend going for a different engine, an RB20DET from any R32 Skyline, A31 Cefiro, or C33 Laurel will work well, and are fairly inexpensive. Also I would recommend changing the rotors and such over to the GTS-T models as well 5 hole versus 4 on the NA cars.
The 20 is an easier conversion than the 25 on a R32 and the engine harness is the same.
Modified by R32MS at 11:53 PM 8/22/2007
