rb20det oil feed size
benj09
Car: Turbo Cavalier
Im sorry if this has come up, but I searched and came up with nothing. Im not familiar with Nissan but im using a rb20 turbo on my car. What is the oil feed size on the turbo? I think my car uses a 1/4 npt for the block.. If someone could please let me know what size I need for the turbo and where to buy, that would be great. Thank you.
rb240det
Car: 1991 240sx Hatchback and 1994 300zx
I know the oil feed line is either 12mm or 14mm (and I believe the pitch was 1.25 also). I'm actually pulling my RB20 out of my S13, so I can get the exact measurements unless someone posts them first.
benj09
Car: Turbo Cavalier
rb240det wrote:I know the oil feed line is either 12mm or 14mm (and I believe the pitch was 1.25 also). I'm actually pulling my RB20 out of my S13, so I can get the exact measurements unless someone posts them first.
thank you, does anyone else know exactly off the top of their head?
BoostFab
Car: S13cp, S13fb, S14z
the oil feed line itself is relatively similar to a AN-4 line, the thread size of the port on the block is 12x1.25 (mm)
Carl H
the oil inlet on the turbo is 12x1.24mm as well, not a common fitting size either...
benj09
Car: Turbo Cavalier
Carl H wrote:the oil inlet on the turbo is 12x1.24mm as well, not a common fitting size either...
you mean 12 x 1.25? kinda confused me lol. but yeah, i havn't seen a 12 x 1.25 anywhere online, but iv seen 10 x 1.25 thats about it. dang!
benj09
Car: Turbo Cavalier
actually i just found one at summit, would this work?
http://store.summitracing.com/...w=sku
Carl H
yes that fitting will work, but remember to run a gt turbo spec restrictor some where in the line as this is a bb turbo...
benj09
Car: Turbo Cavalier
where can i get one of those?
Shahee1
Car: 1993 240sx w RB20DET
I was impatient and tapped my block and fabricated a larger line ... LOL ... don't do anything of the sort ... LOL ...
