Rb20det not starting *solved*
jduke0308
Car: 92 240sx rb20
So ive been looking all over the internet and even emailed raw brokerage to find answers. My problem started 2 days ago. My wideband (innovative lc1) got stuck on 22.4. So i re-calibrate it and its back to normal for that day. Next day cars running fine and randomly the readings go erratic along with my idle and loss of power not electronics but turbo isnt spooling no bov. I pull over and its going from 7.9 to 22.4 and trying to die. i limp it home. Next day i try to start it it wont start. itll turn over but wont start. I ve been looking around and i keep finding a lot of things to fix such as mafs (still wont start even with it out and when it was running once i pulled it out the car would die instantly) ecu fried, a coil pack s*** itself, or ive seen people saying it could be a coolant temp sensor. So hopefully here i can get more concrete answers.
Carl H
blown off ic pipe is my bet.
jduke0308
Car: 92 240sx rb20
wow never even thought to check that. Will do as long as im not snowed in tomorrow lol.
jduke0308
Car: 92 240sx rb20
So there was an IC pipe that blew a clamp and popped off th IC. Still wont start though. just turns over.
jduke0308
Car: 92 240sx rb20
Gonna go get the battery tested just in case.
jduke0308
Car: 92 240sx rb20
tried the battery still good. Only turns over never fires.
jduke0308
Car: 92 240sx rb20
Also checked the codes and i'm getting a 55 so everything's fine according to the ecu. Fuel pressure gauge is at 40 psi so im getting fuel. Any thoughts guys?
Carl H
fouled plugs because it ran with a blown ic pipe and you've tried to start it like that.
boostedh23a1
Car: Datsun 240Z
Datsun 280Z
Yea, check for fire at the plug.
jduke0308
Car: 92 240sx rb20
You guys are freaking awesome!!! she fired up today ran it around and then my maf is starting to give me troubles. But ill hit the junkyard for a n60 tomorrow. Thank you guys so much especially you carl H!
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
try cleaning it with the maf cleaner you can buy. Might just be dirty.
jduke0308
Car: 92 240sx rb20
Well i already swapped in the n60. Was a breeze lol. But #6 injector isnt spraying so ill run some injector cleaner through it. If that fails its off to get them cleaned.
jduke0308
Car: 92 240sx rb20
Injector coil on number six was bad had it replaced now everything is fine.
