Sil240 »
https://forums.nicoclub.com/sil240-u6842.html
Wed Mar 10, 2010 5:12 am
Have you checked the Stickys of How to wire XYZ swap???
But I would only ASSUME that wire would connect to the ignition switch.DO NOT WIRE IT BEFORE YOU SEARCH!!!!
Because there should be the thick white wire that is 12V + for the Coils, then there would be a 12V+ from the batt, a Ground and a Signal wire connected to that relay.
Best bet is to SEARCH!!
