lanerjo »
https://forums.nicoclub.com/lanerjo-u107881.html
Wed Oct 08, 2008 6:48 am
So far I have89 240sx hatch Rb20DET + wired (pain in the arse)R33 x-memberFMICCustom Exhaust pipe for the intercooler piping (to be changed to aluminum at a later date)J30 Diff2" aluminum radiator14" electric fanWalbro Fuel PumpK&N Pod FilterCustom Hood (homemade Cowl Induction to clear the motor)Hood Pins (removed the cable and bracket to save weight)adjustable tension rodsenergy suspension urethane black3" downpipe to dual 2-1/2" catback -cat12psi boostJ30 Front Brake setupMISC weight reduction
Now for the issues i am havingI need a P/S tension bracket was not included with the swap (will modify a KA bracket when i find one)engine site higher than desired (cannot fit my front strut bar)the engine does not like cold startsmisc electrical issues (previous owner was retarded)needs some body work (again previous owner was retarded)Automatic Seat Belts do not work
This was all done including buying the car for $2600usd
Parts on order RB25DET turbo (14psi intended boost level)new eprom for the ecu (tuned for midrange and my mods)Shooting for 280 to the wheels
any ideas on how to solve some of the issues is more than appreciated
