RB20det motor mounts???and another ?
bades
Alrighty guys im almost done with my rb20det swap into my 90 s13.... and i found that one of my motor mounts is busted bad... so heres one of my ?s..
1. Are there any mounts that are interchangeable wit the rb20det ... i am using the gts-t crossmember....
2. I cant find the black/white wire to the yellow and black wire... and having issues wit the white and purple one too...
thanks alot guys...
Neejay
Are you using oem R32 mounts?
bades
yes sir im usin the oem r32 mounts.... im just curious to if say the vg30dett mounts or sumthing will interchange.... or were i can find stock motor mounts...
bades
alrighty guys still having issues wit the black white wire on my rb harness to the black yellow wire on my ka harness... there is no black white wire... on the 8 wire plug... there is a thin black white wire on the 6 wire plug....
bades
ok guys i still cant find the oem motor mounts or other mounts that will work.... any ideas??? because she is done other then the mounts....im about to use hockey pucks as mounts...
Sil240
Car: Nissan S13 "The One Cam Wonder"
To my knowledge there are not USDM interchanges for the RB motor mounts.I would try Raw brokerage. They always have some good stuff.
You could go Dixie cup Isolators.SEARCH it on here I think AZ hitman made them.
You could maybe take your broken mounts and fill them up with Flexane and then maybe Duct tape the together to keep them together while they dry.
Other than that I have no other ideas.
