RB20DET Motor: 2 Green Relays right by the ECU?
CA18Magic
Car: 1992 240sx Coupe/ 2007 Subaru WRX STi
Ok, so i'm literally right around the corner to starting my RB swap.. but my incompetence has stalled my start up.
So story is I was feeding my wiring harness through the firewall, and unplugged the two green relays so it would fit through the firewall hole. Yea, all went well... but now i cant find those stupid relays. I turned my garage upside down for 3 hours trying to remember or come across where i had put those RELAYS!
Can anyone tell me what relays those are? If i can order some new ones? or if anyone has some extras laying around?!? I searched through the FSM 2wice over trying to find a wiring diagram... NOTHING.
Yes i'm desperate... please help?
RustspecS13
Car: '74 260z and '88 300zx turbo
Any green nissan relay will work or you can go to advance and order them, they are like $5-6 a piece.
I had a similar problem, except my injectors weren't getting switched power because the ecu wasn't triggering the relay. So i just jumped the main thick wires so they had power all the time. That was after I bought 2 new relays and still had a problem with no power to my injectors.
~Alex
CA18Magic
RustspecS13 wrote:Any green nissan relay will work or you can go to advance and order them, they are like $5-6 a piece.
~Alex
Good news, found the relays... bad news.. still doesnt start. I'm thinking i have the wrong "white wire" that goes into the ka fuse box. The one thats supposed to match up with the White/purple RB wire... Where exactly is that white wire??
Gabes13
Car: rb20det s13
Wip out that multi meter.IIRC, it's any wire that gives 12v in the "start" and "on" position but 0v in the off.
HIGHFIV5
Car: 1989 240SX
Wiring issues fml hey man!Did you peel back the loom on the wiringgoing into the fuse box?In there i only found 2 white wires.One being thick...and the other being really thick!Im pre sure you need the thick one.I cant really verify, as your farther ahead with the wiring than i am...but thats what one it looks like in this write up.zerothread?id=426543Im having another issue myself. I got a thread a couple posts down.Hope this helps!Good luck hope this thing gets running!
