BSRJIRONMAN wrote:Hi. I recently bought an rb20det powered 240sx and ive got a few questions. every morning at a cold start, it takes about 3 trys to start her up. once it starts, it seems to run fine. The other thing i noticed is when i really 'get on it', is sounds and feels like its misfiring at high rpm's. I sorta hear popping and the power cuts out. Then when its warm, at idle it a has a subtle 'miss' and occasionally bogs down. Any Ideas??? Thanks in advance!
I've been having a similar issue.. I have driven the car so little that I haven't made it a priority, but it's time to do something about it.
I have trouble starting the motor as well after it's been sitting for a while. I can hear the fuel pump and I wait until it's done priming. Then I try to fire it and it has a hard time catching.. Sometimes it won't catch at all the first turn of the key. Then I turn the key again and it usually catches and starts to sputter like it's hitting on 2 or 3 cyl. only. It will choke and sputter for a few seconds, then finally start to fire on all cyl.
I can pull it out of the garage and it runs decent while it's still on closed loop. But after it's warm (say 5 to 10 minutes) it starts to display a bit of a miss when cruising and wants to bog and die on idle.
I've been meaning to change my plugs and I have a set already gapped and ready for install. So i'll do that tonight.
I know that I have a couple broken exhaust manifold studs, and that might be a small issue.
BSR - do you have a fuel pressure gauge? I have a feeling it's my fuel filter or fuel pressure that is the issue.
Another idea might be a new 02 sensor. You can get one from a local parts store under a 1984 Nissan 200sx turbo (CA18et) I think???
