osamathefreak »
https://forums.nicoclub.com/osamathefreak-u199006.html
Sun Feb 19, 2012 9:06 pm
Hey guys,
I've been searching everywhere for weeks and ive found things similar to my problem and tried the appropriate fixes suggested and cant seem to fix it.
Ive got a R32 RB20DET, the engine is 2nd hand to replace a RB20DE+T i accidently bought with the car and blew up within hours. The car starts fine 3sec or so but has an really lumpy idle almost sounds like a subaru, when driving it sounds the same, heres where it gets different.. after 2.5-3k RPM its sounds great! Turbo winds up and she goes like a cut cat. its only lumpy idling and runs fine at high rpm and under boost. Ive done replaced spark plugs, changed coil packs, changed ECU and reset with known Working, check fuel lines and pump, changed oil and water system, checked crank angle sensor. almost everything i can think of ive changed out with known good new or checked.
PLEASE HELP!! So lost for ideas!!
