RB20DET is this critical?
BoostFab
Car: S13cp, S13fb, S14z
how critical is the piece connects to the charge-pipe by the throttle body. i'm going to put in a front facing plenum soon, do i need to incorporate that with the new plenum? maybe eliminate it totally. see the picture below.
gawdzilla
Car: none
depends what that pressure line leads to... however, pressure is pressure so as long as that line still sees pressure (before the TB) you can tap it from anywhere.
goofynick6
Car: 1995 S14.5 RB20DET
That line feeds the idle things...so w/o it hooked up your car will not run right at all..
Spazz
to verify what nick says its the IAA unit, idle auxiliary air unit
gawdzilla
Car: none
in that case you cannot just unplug it. you can T it from another pressure source though, such as that boost solenoid valve next to the red arrow. doesn't have to come directly from the pipe.
BoostFab
Spazz wrote:to verify what nick says its the IAA unit, idle auxiliary air unit
damn, too bad i can't remove it w/o the standalone. no big deal, i'll have it rerouted.
