RB20DET Intercooler??
Sil240
Car: Nissan S13 "The One Cam Wonder"
Hey no one used the R32 Skyline Gts-t intercooler did they??Cause i am just not seeing how it would line upForcing me to get a Front mount which i dont really have money for
What size intercooler is everyone using??And are the intercooler inlet and outlet's on the same side or are they on opposite sides?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
search is your friend.
dareo
Car: 1993 Q45, 1989 240sx
R33 RB25 kit stock SMIC kit from Ebay. was like 40 bucks.
Sil240
what do you mean kit???i have all the stock pipes and the stock intercoolerdoes someone sell pipes that are a direct fit??
frosted flakes
rb20det stock intercooler does work. You just have to get one custom pipe made.
here some pics:
Sil240
cool thanks a lotYeah i was looking at a older post with these pictures in itdo you have a picture of the hole from in the engine bayi just wanted to see where you cut the carthanks
93RPS13
Car: Cars, Girls, Cars, Food
has anyone ever think of a TMIC like the Z31?
Sil240
there's already hood clearance issue's with the rb so that not gonna work out too well
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
HOOD SCOOP WOULD SOLVE THAT OR A HOOD COWL.
Sil240
Yeah but at that point it would be cheaper to get a front mount
PROJECTRB240SX
A HOOD COWL/SCOOP AND FIBERGLASS (W/ RESIN) WOULD COST YOU MAYBE $200.
Sil240
plus you have to paint it, and then you need to make pipes which would be really short and you'd need a IC unless your using the side mount as a top mount, plus you need to make a little heat sheild so it doesn't get heat soakedBecause its on top of the motor
PROJECTRB240SX
JUST GET THE Z31 KIT OFF OF EBAY.... THERE WAS ONE ON THERE FOR $50. THE 200ZR CAME WITH TMIC STOCK AND ITS PRETTY MUCH THE SAME SETUP AS THE SKYLINES.
dareo
We got the R33 RB25 SMIC kit on w/o any custom pieces, just a little negotiating and hose clamps. Something from ebay actually coming with every part needed!
frosted flakes
this is where the intercooler piping is going into the sidemount
Sil240
cool thats exactly what i needed thanks alot
Sil240
hey up to what PSI is the stock side mount good up too??Cause im going to be boosting 12 psi
frosted flakes
ive boosted 12psi on the stock IC and its OK but gets heatsoaked pretty quick. Even at stock boost that small IC gets heatsoaked quick. Really these RB20s need big FMICs and side intake manifolds to get that air nice and cold....
93RPS13
i was thinkin of the FC type of hood scoop
Sil240
what about a 30x5x2 fmic its kinda wierd looking its long and from side to side but short in height
PROJECTRB240SX
I HAD THAT ONE ON MY CAR ORIGINALLY.
Sil240
oh yeah how'd it work??what do you think about if i bought one for 175?
blk90s13
starion front mount any good for RB ?
i have one and i will be running it
it looks big enough also the benefit is i dont wanna route the pipes infront the engine since i am using stock mounts and there is no place for pipes
Yellow4g63
blk90s13 wrote:starion front mount any good for RB ?
Stairon intercoolers suck for flow. They are better than not having any intercooler. I'd much rather run a MKIV TT stock sidemount than the starion.
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
Yellow4g63 wrote:Stairon intercoolers suck for flow. They are better than not having any intercooler. I'd much rather run a MKIV TT stock sidemount than the starion.
I've actually been considering running a MKIV sidemount or a Z32 sidemount... the MKIV one is really big... but it might work.
blk90s13
is that right ?
wut about rb20 side mount vs starion ?
i have yet to hear someone say startion ic suck
but hey u live u learn
Sil240
mo i thought you mounted the R32 one already??what kinda BOV are you running
Yellow4g63
blk90s13 wrote:is that right ?
It's something I learned from RRE. I though they were pretty good intercoolers before too till I asked him. He said it won't flow more but it will cool a little better than the stock sidemount. I haven't heard anything bad about the Stock intercooler. Just that like all side mounts it will heat soak after a while. Just save a little longer and get a good FMIC core. You can get a 20X10X2.75 Griffen Core for around 300. http://www.roadraceengineering...s.htm I tried that intercooler on my DSM. I use to have a Sparco bar n Plate fmic. It wasn't as big as the griffen tho. After I bolted it on the car felt alot more responsive and pulled better vs my old FMIC. The one I have for my RB is Griffen I/C core. I got the bigger one I think it's 24"X11X3.. It's the same one XS uses for there GTR core. I think phase 2 motor trend sells them.
Sil240
do you know if a supra side mount will fit in a S13??my boss has a supra he said he's gonna dig up his old IC for me
Yellow4g63
I have never tried but I'm sure you can make it fit. Just goin to take some time and lots of beer. It's a pretty Thick intercooler.
