Eikon »
https://forums.nicoclub.com/eikon-u15727.html
Wed Dec 08, 2004 10:37 am
I picked up an extra upper intake plenum off of EBAY. Cost me very little... and mostly I wanted the AAC unit that was still attached, so it was worth the money I spent on it.
I have been wondering about modifying it? Obviously my goal is to run the IC piping off the passenger side of the car to an FMIC without having to cross over the engine.
I am just curious if you all have ideas on being able to rework it a bit.
Can the existing hole be welded over and pluged up?Can a new hole be opened on the front side of it? If a new hole was opened, would it still flow air to the back cylanders? What if you flipped the thing over...? used the existing cylander ports but just turned backwards.. then the intake opening would point at the wheel.
Just trying to think outside the box a bit. I like the new plenum DIY kits, but I don't know how to do any of that work, and it sounds like that would get REALLY expensive in a shop to do all the fab work.
Thanks
