I'm not sure if they will fit the r32 rail. The red top fuel rail is diffrent than the silvertop.240+civic=pimp wrote: I have a spare rb20det but it is an r31.
Does anyone know if the injectors in the r31 will work in an r32?
YepCarl H wrote:weird, rb20 injectors on the r32 are redtops (270cc).the yellow tops are gt-r injectors (440cc)
RB25's are 370ccblues14 wrote:i thought r32 rb20det injectors were 370cc. have i been misiformed?
Lets see, Stock Rb20=270 Rb25=370. ECU prgramed for 270cc with 370cc injectors. . . . . . . Hmmmmm thats a hard one to figure out. Another hard one to figure out is the Rb25 injectors are side feed injectors vs top feed injectors on the RB20....hmmm I don't think it's going to fit. I'm going to have to go out on a limb here and say you would need a RB25 fuel rail and injector clips. . . .Or maybe I'm just making this all up....blues14 wrote:so will rb25 injector work on the rb20 without any "issues"? will the stock or MINES ecu be able to controll them? plug and play?
A simple "No, top feed vs. side feed" would suffice.
yup, rb20s have 270's and they are teh suck.i would suggest gtr injectors or 7mgte injectors as a good alternate, however if you use the supra injectors then you will need to use the supra manifold isolators else you will have some big *** air leaks.blues14 wrote:i thought r32 rb20det injectors were 370cc. have i been misiformed?
It's not that I'm from cali it's that you ask stupid questions. If you had used the you could have found the info you were looking for.blues14 wrote:wow, i thought i left all the ***holes on the honda forums!! but i guess your from Cali, so i should expect a comment like that.
