RB20DET in S13 turbo questions
lmnhed
Car: 92' S13 coupe
Alright I have an 89' hatch with an RB20det in it. The stock turbo on there is blown. I am currently trying to find a Z31 turbo in good shape, but haven't had much luck. Either way I have a 57 trim t3/t04e and 38mm tial wastegate sitting in my room, I am currently trying to sell those without much luck locally. So my question is:
Does anyone make an affordable RB20 manifold that is set-up with a t3 flange and an external wastegate? If so could someone point me in this direction. Because I wouldn't mind using the turbo/wastegate that is sitting here collecting dust.
hannibal
Car: Red Line to Glenmont
http://www.turbocalculator.com...25det
That one's made by Stone Racing. Pretty good company from what Ive read. It doesnt look like its got an ext wastegate flange, but thats the only manifold I know about. But I'm not a RB guru. Maybe you should search/post in the RB forums. Those guys know their stuff.
JGS makes cheap (but decent) SR and KA manifolds. For the right price, I'm sure they'd custom build a RB mani. Shouldnt be too hard if they have a exhaust flange or gasket to work from. Maybe you could send them yours??Good luck!
Where are you? Ive seen two Z31 turbos in a junkyard around here. One was an auto with 90k miles. The other was a manual with higher miles...
SeVa-S13
Car: '05 GTO 6spd
All those manifolds are made by SS Autochrome and have a spotty rep at best. Alot of the time it's a hit or miss deal with them. I personally haven't looked for extrnally gated manifolds because I'm going a different route with my RB20 but I'm pretty sure some guys in the RB forums have used externally gated turbos on their stock manifolds somehow. Ask around there.
