Carl H »
https://forums.nicoclub.com/carl-h-u9196.html
Sat Jun 27, 2009 3:52 am
not sure on the coolant line bit...its been ages since i've had my stock plenum.as far as the boost issue goes, it shouldnt be THAT laggy unless you have an rb25 turbo which will run about 5-6psi base off of the actuator and spool around there, without a proper tachometer its hard to tell where the engine is revving just by sound as these engines are high strung and sound like they are revving higher than they are.
does the engine run and idle smoothly?does it free rev smoothly?is there any damage to the ignitor?
in your video you posted it was hard to tell but it sounded like it was missing, might have been the recording or it was indeed missing.
