Powered Bya Skyline »
https://forums.nicoclub.com/powered-bya-skyline-u173821.html
Sat Mar 05, 2011 7:46 am
i thought the same thing, i also had a high idle with the rb20.. come to find out it was the tps the whole time. check the tps you should be getting .5 volts with the tps connected and the car idling.. if its not and you cant get .5 volts turn the car off and disconnect it, check for ohms see if its jumping all over the place is so its your tps. mine was at like 13v.. odd cause its a 5 volt reference. the mintue i tapped on the casing with my finger it would change voltage and same with the ohms
