Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Thu Jun 23, 2011 1:51 pm
Well, since you have been messing with the TPS with no known voltage value readings, you need to set that FIRST. The TPS sensor consists of a ground wire, a 5 volt feed to the sensor, and output from the sensor to the ECU. The center wire, what-ever color that may be, is the voltage going back to the ECU. This is the wire that you will back-probe when setting the TPS sensor. Use a T-pin of some sort and insert it into the back of the center wire terminal at the connector of the TPS sensor. Then, attach your DMM Red lead to that T-pin. Then, attach your DMM Black leak to battery/engine ground. Then start your engine and let it idle if you can. Adjust the TPS until it reads about 0.50 Volts +/- 0.05 Volts, ideal is 0.50 Volts. After that, set your base idle. Adjust the screw all the way out and it should be idling high. Then ring the screw in until you reach your desired idle RPM.
BTW, all it takes is VERY SLIGHT movement of the TPS sensor to get big voltage difference readings.
