rb20det???how much is it worth
Siedsma6
Car: 96 Maxima GLE, 89 240sx se
I came across an rb20det and was wondering if it is worth the money...here is what it has:
rb20det in-line 6 cylinder, single turboUncut wiring harnessECU...i think everything needed for the swap
He also offered to throw in an brand new Limited Slip Differential.
All of this will be $1,000...However, I have to buy a rebuild kit and put the motor back together. (he tore it apart before putting it in his 240 but then sold the 240 for tuition payments and never put it back togethor)
I don't know if it is worth the hassle for the price.Help me out here!~Mike
themadscientist
what color are the valvecovers, are the fairly smooth or ribbed(and not "for her pleasure" haha beat ya to it)
Siedsma6
I havn't had a chance to look at the engine yet...I talked to the guy about it and he said it was in very good condition with barey any visible ware. Obviously i will look at it before i buy it.Just wondering if it is even worth investigating for the price. I'm not familiar with the rb20 engine prices
themadscientist
If the valve coveres are ribbed and red it's an R31 RB20, walk away. If they are silver with dimple at the halfway point proceed.
If he has it tore down this gives you the opportunity to inspect the cylinders for scoring or rust if you see nothing scary proceed. You can check the crank now for spun bearings which would be heat discoloration or some kind of damage on the crank that makes you say "Holy **** what the **** happened"! if all is well go to the deck and check for warpage with a machinist's rule, RBs run hot and often overheat this could warp the block and head at their mating surfaces. Now the head, look in the ports for signs of worn valve guides, sludge and carbon encrusting the back of the valve. Don't worry if the intake ports behind the secondary butterflies look like that, they always do to some extent. look for sludge in the top use your judgement on what you are comfortable with. A properly maintained engine won't have ANY but some is not bad. check the cams and lifters for uneven wear and the whole engine for broken bolts or studs. I'd tell him $800.00 because of the being tore down situation but I would actually prefer this over a running engine as i firmly beleive most of these motors are in need of an overhaul anyway.
Siedsma6
thank you for your input...very helpful. You say $800.00 for it. Would the package be worth $1,000 it if the LSD and new clutch w/trans were thrown in too?
Dattebayo
wow. he wouldnt include the transmission normally? either im mistaken and read that wrong or what?
Siedsma6
you read correctly...he's including the transmission and a limited slip differential.
