rb20det help withmaking 370hp???
Komatsu X
Car: Silvia
hey i have a rb20det with cams gt 3037 turbofmic3in catback550 injecterslightflwheeland alot more .. i wanted to know if i can get arould 370hp with a apexi s-afc are would ihave to get a stand alone fuel manage system like emanage?
thanks
Carl H
you need a chipped ecu, safc might do it as stock maps are pretty conservative...is that a hks gt3037r or a garret gt30r?
Komatsu X
Car: Silvia
its the HKS GT3037 Pro S... how would i go about geting my ecu chipped? I just picked up a APEX'i S-AFC II today.. So do u think i should just stick with that are get my ecu chipped?
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Get it chipped. The safcII cannot run 550 cc injectors on the RB20 as that is larger than 50 percent the original size of injectors. So you have to have a chipped ECU for it to work.... The afc is a nice tool but should only be used for small adjustments.
As far as getting the ECU chipped i myself am looking for that alternative.
Carl H
kansei, you *can* run a rb25 off of a rb20 ecu but you will need to remap it and add a rpm window switch for the vtc to work correctly...
blues14
Car: 1995 Nissan 240SX GTS-t
so gow big an injector can the S-AFC II handle on the rb20? 405cc? one of the new sponsors...Deatsch werks sells direct fit high flow replacements.have you checked out their link?
Valley
Car: 00 celica gt-s 89 240sx hatch
Kansei240sx wrote:Get it chipped. The safcII cannot run 550 cc injectors on the RB20 as that is larger than 50 percent the original size of injectors. So you have to have a chipped ECU for it to work.... The afc is a nice tool but should only be used for small adjustments.
you sure about this? safc's have taken DSMs into the 9's.
DriftingisLame
Car: '91 240sx coupe, rb20det
DSM's already have huge injectors stock (440-450cc's?). So when you plop in 550's or something you wont have to correct as much as 550's replacing 270's, like on the rb20.
Komatsu X
Car: Silvia
I have 440cc inJectors .. Do you think i can reach 380hp with the 440cc injectors and the S Afc?? are should i just get my ecu chip? i really dont want to spend exter money if i can do it with something i have here at my house..
mugengsr
Car: SKYLINE GTS-T TYPE-M
i dont think you will be able to trim the fuel down enough with an safc to make it run right with the 550's in it .. 440cc gtr injectors are still a chore .. ecu tune would be best .. then use safc for fine tuning ..that setup is more than capable of 370hp with correct tuning
clet
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Komatsu X wrote:I have 440cc inJectors .. Do you think i can reach 380hp with the 440cc injectors and the S Afc?? are should i just get my ecu chip? i really dont want to spend exter money if i can do it with something i have here at my house..
Sweet anther RB20 local to me. Lets RACE!!! j/k my car is not running yet lol. Hit me up man, I'll show you a good place to get dynoed at.
Carl H
you will need 550's to keep the duty cycles sane, i know this is a highly debated topic but i run larger than neccisary to keep duty cycles down...380whp is roughly 440bhp, so those injectors would be screaming...
Komatsu X
Car: Silvia
sweet im down to ride but in my street car i think it has around 300hp right now .. i got alot of friend at uti so i can get my car dyno for free . well if your down to drift hit me up anytime if i have gas im down lol....
Yellow4g63
No Drifto action for me. Let me know when you get your car done.
Komatsu X
Car: Silvia
well just roll ill be doing alot of drifting tho
mugengsr
thats is true carl .. the 440's would be working their *** off .. i was not aware he wanted about 370 whp .. either way 550's are a must and ecu tune is also advisable..
