AxiOn419 wrote:I do not know the answer to your question but I just saw that intake for sale on ebay or http://www.japengineshop.com/i...e=777
i think its a rb25 block with a rb20 crank ?! ....Carl H wrote:rb24 is a rb26 crank and rods with custom 82mm pistons.
you get it ... but it wouldnt make sence without the eccs and the rb25 head ...jdmser wrote:The RB24 their talking about on Wiki is the rb25 block with the rb20 crank which does have the bigger bore and is sohc and carbbed.
http://en.wikipedia.org/wiki/Nissan_RB_engine wrote:This is a relatively unknown engine, as it was not produced for the Japanese domestic market. These were fitted to some left hand drive Nissan Cefiros exported from Japan new. Mechanically it is made from an RB30E head, RB25DE/DET block and RB20DE/DET crank with 34 mm height pistons. This engine used carburretors instead of the Nissan ECCS fuel injection system. It is able to rev harder than the RB25DE/DET (as it has the same stroke as the RB20DE/DET) as well as being almost the same displacement as the RB25DE/DET. A common modification is to fit a twin cam head from other RB series motors while retaining the carburreted set-up. The standard single cam form produced 141 PS @ 5000 rpm and 20.1 kgf·m (197 N·m) of torque @ 4400 rpm.
