Xit40 »
https://forums.nicoclub.com/xit40-u25227.html
Sat May 14, 2011 5:40 pm
Something is not right with those results. If your not getting compression a leakdown test should not hold 95 psi. Since the wet test didn't improve your compression results you can be fairly sure that your piston rings are ok.
I would boost leak check it first to make sure there are no external problems like vacuum/boost leaks. If that turns out good move back to internal checks compression and leakdown. There is definitely something odd going on with cylinder 3 so i would focus your search there. Maybe even pop the valve covers off and verify that that your valves are working as they should. Double or triple checking the timing, by hand first, is always advised.
Is there a chance you scored the cylinder walls below top dead center when your oil pump went out? That's the only logical explanation I can imagine that you would get no compression yet the leakdown shows no leaks really. The leakdown test should be able to pinpoint the problem. When doing the leakdown on cylinder 3 start it at TDC and slowly move the piston down in the stroke to see what happens. It should hold pressure if everything is good until the valves open. If it doesn't then you most likely have cylinder wall scoring that's causing the problem. Report back
