RB20DET Got motor might as well rebuild/refresh
LeD ippen
Car: 1993 Nissan 240sx SE
Part and work list (Some part number included
Rb26 T-belt M-13028-20P25
Belt Tensioner M-13070-5L300
Rb25 Idler Pulley M-13074-58S00
Rb Tensioner Spring M-13072-58S10
Rb20 Wtr Pump M-21010-70TY5
Rb20 N1 Oil Pump 15010-24U01
Rb20det Gasket Set M-A0101-04U2F
Exedy 06-801A
Fuel Pump GSS341-400-766
Spark Plugs bcpr6es-11
E-Fans
Radiator MMRAD-240-89KA
Intercooler Kit KIT016-IC0022
Motorset
Thermoswitch
Gauges
AFR 22670-RR710
Exhaust 12-N010S
Braket 22672-RR710
Nismo Pivot Ball 30537-RS540
Head Studs 202-4301
Down pipe
Dump pipe
Exhaust Nut 08912-8401A
Exhaust Stud M-01151-00471
Crossmember
Machine work Block
Machine work Head
Machine work Crank
Machine work Rod
ACL Rod Bearing 6B2630H
ACL Main Bearing 7M2394H
Arp Rod Bolt 202-6003
Crank Collar
Tomei Orifice 191710
Nismo Thermostat 21200-RS580
Crank Timing Plates 13023-42L00,13022-42L00
Intake and A/c Compressor
BM Shifter 45088
Fuel Pressure Gauge
Yoke 14037-42L01, 14037-42L02
Rings 12033-59S00
Ecu
Nistune
Oil cooler
Mounts Can use E30 3 series mounts bmw 86-91
Timing Drive Gear 13021-42L01
Woodruff Key
Cometic intake gasket from Eric perfromance part since the one with kit was ripped
Pictures
The Car
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I'd just use the Rb26 oil pump normal N1 isn't all that and cost more money.
LeD ippen
I was going to use the stock rb20 pump but decided to get a new one. normal costs about 160 and n1 cost 210 so i just got that instead. I brought 2 restrictors because i dont like the idea of one being blocked off. i like my oil to be spread evenly.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
what you consider a "n1" pump is a normal oil pump. a real n1 cost close to 1000 usd. and yes a n1 oil pump is the shiznat compared to a normal pump.
Yellow4g63
SullivanRacing06 wrote: what you consider a "n1" pump is a normal oil pump. a real n1 cost close to 1000 usd. and yes a n1 oil pump is the shiznat compared to a normal pump.
The N1 pump sucks just as much as the normal pump. It just runs a little higher in the PSi vs the normal. You won't be taking the N1 to 10k rpm and watching it live. The 1k pump like the Tomei, Greddy and ect those take the hit. http://www.skylinesaustralia.c...+pump
LeD ippen
I research mixed reviews and some people done some while other did this and that and are fine.this taken from a guide
"Many have had success using the RB30ET oil pump.It is best to use an oil pump from a twin cam motor as these provide more flow and pressure.All RB oil pumps are interchangeable.I’ll stress again. The RB pumps do have a reliability issue and crack if used at 7000rpm+ and high km’s without a crank collar.Ensure you use lock tight on the bolts when assembling the oil pump as they are known to rattle loose causing a gradual loss of oil pressure."
Hmmm I am just going to use the n1 pump, oil restrictors, crank collar, and locktite the back plates bolts. i let my emotions get the best of me and i usually take it out on the car. so here's to hoping. i never hit rev limiter anyways because no torque >.>. I am doing a lot of tracking and autocrossing lately every week or two and I beat on the motor. so everything should be needed. just not gonna do the oil drain in back of head until Coolwhip gets into making a good thin version using wesch plug. /hint /hint
Monogato
Car: 1989 Nissan 240SX SE
Got the same timing kit from Nissanparts.cc, which they would've sent me two same color stickers! I got the same color combo :P
AZ89two4Tsx
How much did u spend total on the rebuild if you don't mind me asking?
LeD ippen
Ballpark figure is something like around 2 grand for timing, gasket kit, crank collar, machine work, oil pump, rings, bearings, headstud, rod bolts, water pump, crank drive gear and some others im forgetting, probably around 2.7G total. doing all the work myself . besides the machine work.
Chaos the Xile
Car: 1974 Datsun 260Z
I have a RB20 and needs new rings I see your part # listed but I just wanted to know what website you purchased them from. If any I was going to call my local nissan dealer and have then check on the part tomorrow
LeD ippen
I got it from nissanparts.cc for $82.
jrd450r
Car: 1990 RB25DET S13
Nice rebuild! Not to thread jack but are those part numbers for the idler and tensioner pulleys the same for the rb25? I'm about to order them but just wanted to make sure first, Thanks!
LeD ippen
It should be the same. If not there something wrong :O
LeD ippen
Got some stuff and block back from machine shop
New Snout on
hone cleaned and deck block
LeD ippen
rod piston crank in took 2 hours though <,<
d356bud
Car: 1990 240sx w/ RB25DET
nice, keep up the good work
miguel granville
Car: nissan tiida
what kind of Machine work did you do on the engine ?
also what kind of bearings did you use ?
LeD ippen
LeD ippen
the belt smells like new shoes >.>
Just got it cleaned, honed, snouted, decked, and resized. there was a lot of rust and chunks of it. that why i took it apart. the motor was sitting for like 5 years, i m guessing although motor look real low milege like 20k low or less maybe.
LeD ippen
Well lets just say the motor was easier to put in then taking out the ka.
The swap is very easy if you are mechanically incline. there were a lot of fabbing but meh. wiring was so easy. all the talk on forums made it look harder then it is.
well its running and omg it feel good after i drove for 400 miles with 1 bad injector. now it pulls like no other and at 20 vac im loving it.
bumper and support now on though have to redo the hot pipe from turbo but too lazy
sci2000tech
Car: '92 Nissan 240SX S13.5 RB20DET 'Vert
Lookin great, keep at it :dblthumb:
