rb20det fuel pressure regulators
wantsansr
Car: 1993 nissan 240sx se coupe
got me a rb20det out of a 93 gtst. now my fuel pressure regulator is bad problem being i have 2 fpr's one is at the front of the rail and the vacuum line is plumbed in after the throttle body. the second is at the end of the rail and is plumbed vacuum wise before the throttle body. im assuming the one at the front of the rail is active during vacuum i.e. not under boost and the last one is for under boost. question being.... has anyone else seen this and do you have a part # for them so as that i can see if nissan can get them???? anything will help... and if you can confirm if my assumption is correct about one for boost and one not.
rb240det
Car: 1991 240sx Hatchback and 1994 300zx
Got my NISMO fpr from courtesynissan.com....
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
If you're running a more or less stock setup, dont even begin to **** with an FPR. The stock one is plenty good.
wantsansr
my fpr's are bad and was wondering if any one ha part #'s
themadscientist
Some come like that, it may be a kouki/zenki thing. I have never been able to figure out what the determining factor was. Just cap the one on the back and stick you a new one on the front, problem solved.
