Bronze MFP »
https://forums.nicoclub.com/bronze-mfp-u7726.html
Fri Feb 09, 2007 8:51 am
whats wrong with stock(ish) HP? i've been rolling around like that for a year and am still having fun with it.
as for cost, quit throwing the freakin mout kits in on an rb20 swap... its expensive and unnessisary. Here is what my swap ran, roughly:
engine set from jhot: $1,650 shippedr32 crossmember from jhot: $80 shippedjun lightweight flywheel: about $300 shipped (cant find prices on nengun anymore, discontinued)RPS sport clutch z32 $284Tomei fuel pump: $287nismo engine mounts: $71.23 shppied each (x2)Nismo trans mount: $75.37 shippedGreddy timing belt: about $100 shippedtiming belt idler and tensioner pulley: $160
apexi air filter: $91.16
water pump about $100 shipped
thermostat about $65(cant quite remember on that one but whatev)
greddy profec-b boost controller $150
gauges (boost, water temp, afr) $300
misc hoses, radiator hoses and heater hose adapters: around $100.00
factor in about another $100 for trans oil, coolant and engine oil
thats a grand total of $3919.99 of stuff I can remember. some of those parts were unnessisary, like the air filter or the light flywheel and boost controller, but you get the point. Swap was done december of 2005, and since then I have put on 36,000 miles. not once has the engine died on me, not started for me, or been a blast to drive. Will i upgrade power in the future? sure, but the stock swap is nothing to scoff at. its fun, reliable and not too horrible on gas. now for going KA-T? better buy a good kit... ask carl h how his install on a friend's car is goin lolz!
