Rb20det Engine QUESTIONS
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
DOES ANYONE KNOW:
HOW MUCH THE CYLINDER HEAD FLOWS?THE TURBINE COMPRESSOR MAP?THE CAM PROFILE?VOLUMETRIC EFFEICINCY?
HAS ANY ONE FLOW BENCHED THE CYLINDER HEAD YET?
THE REASON I NEED THIS STUFF IS BECAUSE I'M TRYING TO INPUT THE SPECS INTO THE COMPUTER SO THAT I CAN DESIGN MY CUSTOM ENGINE.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Might want to try these guys found some good info looking around but haven't got my email to join it yet.http://www.skylinesaustralia.c...hp?s=http://www.r31skylineclub.com/ Older version but you never know someone might know something. there was one other forum but I couldn't even get an email off because they ban Yahoo and hotmail accounts??? ohh well hope that helps you in your quest.
meggala
cams are 240o not sure on lift the turbo in small 42 mm exhaust wheelshead 400-450 hp they will flow.the rest I dont knowcheers
PROJECTRB240SX
OHH I MEANT,CFM @ 1.5INHG FOR HEAD FLOW TURBO I NEED CFM, PRESSURE RATIO, SURGE FLOW, AND EFFICENCY.
CAM PROFILE I ALREADY HAVEHERE FOR REFERENCE: 240 DEGREES WITH 7.8MM OF LIFT AND THE INTAKE CAM HAS A CENTER LOBE OF 115 AND EXHAUST 110.
