rb20det engine problems
240+civic=pimp
Car: s13/rb20det, 2002 WRX, 1994 Yamaha fzr600
So it turns out my gas gauge dosnt work and i ran the rb out of gas.I finally got to put everything back to gether yesturday and put gas in it and it ran like sh*t. I made a knocking noise at idle and then it went away after about 5 minutes.I then drove it around and it was working fine.then the car wanted to die it bogged down to about 10 mph and was backfiring.I made it home.i started it up again and it ran fine.Later again in the night i came home to drive it and it was running good and then decided to bog down again to like 10mph and full throttle.i stopped the car and then drove away like nothing happened.???????????????????????????????????????????????????????????????????????????????i have no clueany suggestions.adam
Carl H
sounds like the ecu is throwing a code for something.pull codes and see what it says.
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
Have you tried changing the fuel filter? Did you do it when you got the motor in there in the first place? Running a tank empty is a good way to clog them up.
BoostFab
Car: S13cp, S13fb, S14z
could be air in the fuel line cause this problem?
240+civic=pimp
There was sh*t in the fuel tank.It runs great now!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
