Rb20det emanage wiring question ....
preston240sx
Car: Nissan 240SX S13
ok so i bought a blue emanage for 140 bills which was a steal i think anyway my question is i have a few wires im kinda confused about and before i hook i up i thought i would ask about whre they go as i dont have a installion book i know the main wires but there's a couple im not 100% on
ok so i have the 18 pin harness on the emanagethe wires are
pin 13 nadapin 14 airflow2 (voltage ) inputpin 15 airflow (voltage) inputpin 16 TPS sensor input pin 17 injector input signal input ch1pin 18 injector input signal input ch2pin 19 injector input signal input ch3 pin 20 injector input signal input ch4pin 21 nadapin 22 airflow1 (voltage) outputpin 23 rpm input signalpin 24 ecu groundpin 25 ignition powerpin 26 nadapin 27 nadapin 28 nadapin 29 nadapin 30 injector ground ( sensor Guard)
ok so that what i have from the harness is this the right harness? should'nt there be 6 injector input signals? not 4 ? anyone knows lemme knows thx
where do i wire the injectors to in the rb harness if so im just makin sure thx
Modified by preston240sx at 3:48 PM 4/17/2009
jdmser
Car: duh
tomorrow when I haven't had so many beers I'll look up how I did it and let you know
preston240sx
ok ha nevermind the trying to hook up thing i got it .....after printing and reading the manual lol i found the emange was set up for a rx7 lol now its set up for a rb but still had problems...had a green light on start up and it stayed for awhile but turned into a fast flashing red ...
