rb20det ecu w/ rb26dett??
aero1310
Car: 90 300zx with rb26 swap
Got a question here, im a bit puzzled and really have no clue where to look or what to search under, but here we go. Ordered an rb26 engine off of ebay, took it apart and just completly looks rebuilt with aftermarket parts: heres my swap thread with pics of everything http://www.wisconsinzcrew.com/...743.0
but anyways the car came with a ecu says rb25 on one side and rb20 on the other side. Then I looked up the part number (which is 23710 11U00) and looks like it goes for a rb20det....
Why would I get the wrong ecu?? will this ecu work woth a rb26? Im almost thinking the car had a aftermarket ems or something so they pulled that off and grabbed a ecu sitting around and threw it in there.. im already confused about ems and the electronics lol this just makes it worse
Carl H
proly swiped the ecu...sucks because that thing is going to hate life on a stock ecu unless you tune it.im gonna bet it has large injectors too seeing as those look like hks 2530's and with hks cams as well as a possible built bottom end some one was making power with that engine.
aero1310
haha soon to be me, just gotta figure out this whole engine management crap
legit240sx
Car: 91 240sx rb20
dude i hate you but really i just wish that i got a built motor haha lamage but dude if i was you id be hecka happy thats like another 4g's fo free, unless you payed like 6gs for it....
aero1310
haha 3200 on ebay... what you guys think i should do about the ecu? can i order a rb26 nistune board and throw it in place of the rb20 board or do i gotta order the rb26 ecu and buy a nistune board for that? that engine is worth more than what i all own lol I dont want to hook up the rb20 ecu and hope it dont go boom boom pow
Carl H
you could try the rb20 ecu but it is a serious backstep from the standard 26 gear...you need to also check and verify the injector size on the engine since its been modified...a stock ecu will not run larger injectors.
aero1310
If I order a rb26 ecu and use nistune think that will work? also think the wiring harness is still useable?
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
i have a stock r33 rb26dett ecu wich you dont need now and it probably wont even work for you since you have an r32 rb26. how much did you pay for that motor cause you got really lucky and i mean lucky with all those parts.
Modified by HxC_Nismo at 5:37 PM 7/13/2009
aero1310
well i scored a r32 rb26 ecu off ebay for 50$
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
HxC_Nismo wrote:how much did you pay for that motor cause you got really lucky and i mean lucky with all those parts.
HKS all over the place... good find!
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
yea, very nice find man as long as everything is sound. I would crack open that ECU and see if it's been modified at all.
aero1310
Coolwhip wrote:yea, very nice find man as long as everything is sound. I would crack open that ECU and see if it's been modified at all.
what do i look for? how can i tell if its been modified? also found out theres a HKS MAP sensor hanging off the engine so Im guessing they had HKS EMS
Coolwhip
Vendor
aero1310 wrote:what do i look for? how can i tell if its been modified? also found out theres a HKS MAP sensor hanging off the engine so Im guessing they had HKS EMS
Did the engine come with MAF sensors?
Could of had a HKS VPC Installed along with a ROM Tuned RB20 ECU to run a MAP. What I would look for is any modification done to the board or a swapped rom. (but i guess they would all look generic?)
Or perhaps it may have had a HKS FCon (pro) of some sort installed and the guess of the person throwing in the available RB20 ecu was the case.
aero1310
I was thinking they had HKS FCON since the whole block is pretty much HKS... This is my first engine swap and I never used "piggy back" systems or anything like that before so Im a little confused still how this all works. does the fcon like manage the engine and you use the stock rb20 ecu to run all the other stuff like gauge cluster and lights and stuff?
no the engine didnt come with the maf sensors
Also Im looking at trying to get at least 400-600HPI got the rb20 ecu and wiring harness hooks up to it and all plugs on the engine. I ordered the rb26 ecu just in case i need it. I wanna use nistune with the rb26 ecu, think that will work or will I need to buy something more expensive to get those hp numbers?
Modified by aero1310 at 9:32 PM 7/14/2009
Modified by aero1310 at 11:05 PM 7/14/2009
Coolwhip
Vendor
could of been hooked up to a Fcon as the determining factors are really pointing to that:
HKS Engine PartsHKS MAP SensorAbsent factory MAFSAbsent factory ECURandom RB20 ECU attached
Might have noticed it was worth some coin and pull the ECU off of the motorset and swapped it out with this one.
The FCon is a stand alone which replaces the factory ECU altogether and manages the engine and all the other tasks the original ECU did.
aero1310
got the rb26 ecu today! talk about "overnight parts from JAPAN!"
Right away I decide to take them both apart and compare, looking at other ecu's from the internet, looks like my rb26 ecu was chipped how lucky, but downside it looks just a little beat up.
abubika345
Car: 90 hatchback sr20
If you wanted to save some money you could always use the freeware rom edit program with a base map and tune from there.
Ive seen up to 500hp done like that.
