LeX »
https://forums.nicoclub.com/lex-u37537.html
Fri Oct 27, 2006 3:50 am
I'm new to this engine so not really sure what's up.
If the car is left to idle , it will just slowly die out.I just replaced the fuel pump, and after that it would idle at 600-650, but then after i started driving it, it stopped.
On rare occasions when its sitting idling it will rev to 2000, come back down, rev to 2000 in a consistent rhythmical pattern.
I'm trying to get this car to idle normally..
only mods are 3" turboback and FMIC
It has a maf blow thru, perhaps that could cause an issue.What should i be looking at. IT has new spark plugs.Maybe the MAf blow through or coil packs or what would cause this
i was also thinking maybe if I install a new FPR that could fix it, but i had this problem before i installed the new fuel pump
