With TunerCode firmware and TunerProRT, you can log knock count and the knock timing adjustment, and you can tune the parameters that control how much timing is pulled based on the knock count, and the maximum knock retard based on load and rpm.NewKleer wrote:no software will show knock readings, they arent available via consult. just have to assume that if there is no error code, that its OK. or get a knock lite or similar.
yeah, sorry i meant to say without modifying the board/ROM there's no easy way to get a nice number like the powerfc has, which is what people are normally after when they ask the question.dfddfd2 wrote:With TunerCode firmware and TunerProRT, you can log knock count and the knock timing adjustment, and you can tune the parameters that control how much timing is pulled based on the knock count, and the maximum knock retard based on load and rpm.
TunerCode isn't currently available for the RB's.Sil240 wrote:dfddfd2 -
How much is this Tunerport?
Does it work for RB's?
I don't see any listed.
well if the sensor is buggered or the ECU still thinks its cold, then it will open AAC to help idle higher. so would be worth confirming consult is reading like 80C+Sil240 wrote:NewKleer-
Not sure at what temp the engine is at when the AAC is at 80% and 1200 rpm.
But the car is up to temp and in Closed loop.
I screwed the AAC all the way IN, just to get to a 1200 rpm idle.....
I did notice that when I unplug the Air Regulator NOTHING happens. Vacuum is coming from the Air Regulator to the bottom part of the Tee going to the AAC.
