If it aint broke, dont fix it. I would make sure that it is broke before I just tore into it. When you start doing this rings and stuff, then you should replace the rod and main bearings too. You can do a leak down test while its out to determine if it does infact leak comperssion.kevy8up wrote:would it be wise to do a rings and seals rebuild when u get the engine in. Since one would have it out and eventually swap it.
what?PROJECTRB240SX wrote:A LEAK-DOWN TEST IS ONLY EFFECTIVE IF HE SMELLS FUEL IN THE OIL.
crxcess wrote:Thats what I did...the car was warm too. Brand new tester.
