Nameless EJ6 »
https://forums.nicoclub.com/nameless-ej6-u7239.html
Tue Mar 29, 2005 5:36 pm
There is no general number.
It is consistency across all cylinders. If all cylinder are at 25psi, then that's good. Your gauge would be stuffed..
Do yourself a favor, skip the compression test and go straight to leak down. You don't need a comp test if you have a leak tester. Leak > comp.
