RB20DET clip arrived yesterday...
Monkey87
Car: 1995 240SX SE/RB20DET
After waiting for six months, Jarco finally got my clip to me. Haven't taken it all apart yet, but it looks good. Manifolds are in good shape, no sign of oil leaks or coolant leaks, need a new intercooler and piping, though....but, they cut the entire rear end, suspension and everything, and gave it to me. So now, here is my list of goodies to stock up on...
Water PumpTiming BeltFMICOil PumpAll GasketsRear Main SealKoyo RadiatorDual Electric Fans (Need some advice....push? Pull? What brands are good? How big?)Custom Downpipe (if needed)HKS SSQVApexi N1 muffler with custom catbackHope to balance the crank and rodsJE or Wiseco pistons
That's about all I can think of right now. What of these things are absolutely the best to replace right now? I know the oil and water pumps, timing belt, and gaskets....is there anything else I need to change before it's in the car?
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
crank collar for shure. A set of arp head studs wouldnt hurt also.
Carl H
midas well do arp main and rod bolts/studs too if you plan on revving hard and oil mods.
Monkey87
Well, it's not going to be a racer, I'm going to take it down the track a few times after the swap and see what it runs so I know for sure, and then it's just going to be a daily driver. I don't dog my car either, so high revs aren't necessarily an issue. The crank collar, though, thank you much. I forgot all about the RB crank collar issue. Main and rods studs/bolts...ARP, too, I suppose? Where is a good place to find the oil and water pump, etc.? Thanks for the advice guys, hopefully this swap will be underway within the next month or so. For now, I'm going to save up for the parts and tear it down and clean every square millimeter of the inside of that engine.
Carl H
if you dont plan on making more power than stock or racing (track or drag) then pistons are a bit overkill.
blues14
Car: 1995 Nissan 240SX GTS-t
go to http://www.nismoparts.com my friend Shea M. runs that site for bruce titus nissan in tacoma,wa. He has an rb20 s13 and has ordered some stocking parts for his dealerships parts department. If he doesnt already have it, he could probably get it, without gouging you. let him know Doug reffered you:)
240wootie
Car: 1989 rb20 coupe, 2002 WRX
man, wish i would have known about that place when i did my swap.. they have good prices!! to the op^ good luck with your swap, looks like you have a good list of parts!! if you dont already have a walbro fuel pump, it would be a good idea
ninety1two40
Car: 1991 240sx SE
I recommend the Flex-a-lite 210 electric fan, it's a dual 12" puller setup. I bought mine from Jegs.com. The clearance between the fans mounted on my S14 rad and the power steering pulley on my RB25 was really really tight. I ended up notching my radiator support about 1/2" and moving the radiator foward. BTW, my Rb25 is using the SYKO mounts. I'm not sure if the RB20 would have similar clearance issues or not.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
blues14 wrote:go to http://www.nismoparts.com my friend Shea M. runs that site for bruce titus nissan in tacoma,wa. He has an rb20 s13 and has ordered some stocking parts for his dealerships parts department. If he doesnt already have it, he could probably get it, without gouging you. let him know Doug reffered you:)
I ordered some exhaust manifold studs and nuts from them.
Monkey87
Sorry I've been away for a few days....had finals and all this week, so it's been crazy. But yes, this car is going to be a daily driver, not looking for big horsepower, but would love to be able to leave a Mustang staring at my @$$, if you know what I mean. Thanks for all the advice guys. I'm going to start trying to get the wiring diagrams together, and maybe I can do this myself.
