RB20det chip?
Beastin_RB
Car: 1995 240sx RB20det swap
hey i'm new to the site and i have a question. there is a stage 3 chip? or somethin of the sort on ebay and it seems to be a big help but i was just wonderin if anyone has used them? or if there are any other chips available for an RB20det as this is my first nissan. thanks in advance.
derek
DriftNGo
There are "chips" available to tune your RB20DET. I think most people on here would recomend shying away from chipping your computer unless it is done by a reputable company. If it is just a chip you are looking for Contact Carl H. on here, I understand he does great work.
Then you have the Nistune option... This is a realtime editable daughterboard that gets installed like a chip into your ecu. This would be a much more viable option and you would then be able to modify the settings for any future modifications you make. These run about $400.
The third would be to go with a stand alone unit but these are expensive. There is someone in the forums setting up a group buy for the haltech units i believe in the neighborhood of $1600.
Hope this info helps.
synergy
Car: s14 rb25 s1
Just as a little side note reffering to car parts in stages is the fastest way to get made fun of.
Beastin_RB
synergy wrote:Just as a little side note reffering to car parts in stages is the fastest way to get made fun of.
i usually dont but that is what is called lol.
Beastin_RB
and yes that helps alot i didnt think that cheap chip would work but the nistune option may be the way i go
synergy
Car: s14 rb25 s1
I would never buy anything thats a "stage" except a clutch. But even then i want to know the tq rating. Nistune is good and cheap and will retain alot of your factory ecu options and nice idle.
Sorry about the stages thing im just sick of 500hp civics with a stage 3 engine.
Beastin_RB
oh trust me i know all bout the little honda kids we have like a billion in my town. but ya i'll be askin alot of questions in the near future. this is my first nissan and its all new to me. like can i get my stock tach and speedo to work? its a 95 240 with an rb20
Carl H
stock tach and speedo should work if the sensors were installed and the wiring was done correctly.
Beastin_RB
well they dont work and wiring scares me to be honest lol idk i may try to find a place to wire it up
synergy
Car: s14 rb25 s1
Carl the tach reads correctly? I thought you had to modify it in someway. And also im sure you know but would this trick work....
Using a battery measuring output voltage and turning the screw untill it decreases by 33%? I know there is a trick to doing it but i would never make you devuldge your secrets And i know the whole rev to 3k turn till 2k trick but my car isnt running at the moment so its hard to do....
OOOOO new idea tell me if im stupid.... I have an 02 sentra never looked at the diagrams at all could i use that car to recalibrate it with a muiltimeter That can read rpms?
Havnt looked at the diagrams to see if thats even remotely possible.
colbol89
Car: 1995 240sx with SR20DET swap
synergy wrote:I would never buy anything thats a "stage" except a clutch. But even then i want to know the tq rating. Nistune is good and cheap and will retain alot of your factory ecu options and nice idle.
Yeah I second the whole "stage" chip bulls***. From my knowledge a chip or tune is really only going to be useful if it knows all the mods you have done to your car otherwise it's worthless. As for pushing a stock motor harder than it normally is intended for without any further mods...never really a good thing in my book. Sure you could probably squeeze a little more power out but reliability and the wear on the parts would have to go up.
DriftNGo
Beastin_RB wrote:oh trust me i know all bout the little honda kids we have like a billion in my town. but ya i'll be askin alot of questions in the near future. this is my first nissan and its all new to me. like can i get my stock tach and speedo to work? its a 95 240 with an rb20
For the speedo you will need to get a speed sensor off of a manual KA transmission and put that into the RB transmission... this was all I had to do in order for mine to work but I used the lower KA harness.
In order to get the tach to read anything you will need to wire in a 10k resistor and a 12v source to the signal wire going to the tach (look up step up resistor). This effectively (correct me if I am wrong) takes the ground signal from the RB ECU and turns it into a 5v signal for the KA tach. You will also need to recalibrate the tach as it is a 4cyl tach and you are now running a 6cyl engine.
Hope this helps
Beastin_RB
ya that helps alot but i've never messed with wiring or tachs so how do i recalibrate it?
Sil240
Car: Nissan S13 "The One Cam Wonder"
Hey I don't know what your running, but I have a chipped ecu that I'm not using. It's chipped for a rb20 with 550cc Injectors, a rb25 Turbo no Speed limiter and raised Rev limit to 8200.This Guy in the army in Germany chipped and burned this Ecu for me. Lmk if your interested.
But +1000 for Carole on wiring and chipping. He's a good dude.
synergy
Car: s14 rb25 s1
My tach reads but it reads off.. I also am interested in calibrating it since it has a potentiometer in the back there is deffinetly a way to do it.
