peetzi »
https://forums.nicoclub.com/peetzi-u271376.html
Tue Jan 24, 2017 12:07 pm
Little of listing what is done so far..
Bottom end,
Supertech 0,5mm oversized forged piston set
Speedimports conrods (Only found here in Finland, rated and tested up to 200hp/piece)
ARP bolts at the critical places
ACL bearings
N1 oilpump
Crank Collar
N1 Waterpump
Tomei Oil baffle plates, oh yes they fit to Hnr32
ACT 6-puck extreme sinter clutch
Nismo RSR21 Lightweight
Ross Harmonic Balancer ( coming up next )
Head,
Supertech +1mm oversized forged in and ex valves
Supertech bronze valveguides and seals
A lot of porting
Tomei Pulleys
Tomei Timingbelt
Tomei Headgasket
RB26 cam covers, painted wrinkle black
RB26 ITB's+plenum+TPS ( under the knife atm )
New Garrett GTW3476R on its way
* Compressor Wheel Inducer: 58.3mm
* Compressor Wheel Exducer: 76.4mm
* Compressor Wheel Trim: 58
* Turbine Wheel Inducer: 65.0mm
* Turbine Wheel Exducer: 56.6mm
* Turbine Wheel Trim: 76
0.82 AR housing
For that garrett, a custom made exhaust manifold. Material is ready, just waiting for the turbo, so the manifold build could start.
This far in a year and half..
Pictures coming soon !
