tecnic1 »
https://forums.nicoclub.com/tecnic1-u37333.html
Mon Aug 28, 2006 2:42 am
Mine does it too.. additionally, it dies when decelerating, sorta like I was using a blow off valve.first and foremost, 1400 to 2000 is way too high for your idle. When I was first driving mine, it was idling that high, I had the idle air adjustment all the way rich, and it was still idleing that high.After a lot of trouble shooting, I found a grounded wire at my ecu. The plastic cover over the connecter had cut a wire and was grounding it to the ecu. Once I fixed that I was able to get my idle into a more reasonable range ( 500-1200).that's as far as I have gotten. I've tried hotter plugs, cleaning the maf sensor, checking the tps and checking timing(which is difficult because I have only a rough idea what RPM it is at, I'm using a "guesstimated" s14 tach), The only things left are the o2 sensor, which is going to require a lot of work because my o2 sensor bung is very poorly placed on my downpipe, finding a digital timing light and rechecking my timing with a more accurate rpm, and checking for boost leaks.
anyway, there are a few things for you to look at.
