Seishuku wrote:It's physics... lol
But I ran my SR blow-through for years, didn't need to adjust for anything.
If anything, it may run a little richer, but the SAFC isn't playing you any favors though, I'd be more worried about that blowing the motor than running a blow-through.
why I'm not compensating any fuel ratios at all... just using it to piggy back ecu to tell my ecu i'm using a z32 maf and venting bov.
I've just heard that because the flow is more restricted in the hard piping that the voltage reading from the maf are slightly higher. Ex. a usual 4v reading being 4.9v... I know in a stand alone setup i could change the maf voltage table readings to compensate, but I'm not sure that the safc2 is capable of that. but i see so many blow thru setups with only an safc tune.
