rb20det base map
veloce240
hey guys
I just bought a AEM EMS series 2 for my 240 with a rb20det. I converted from MAF to MAP and i need a base map so i can get the car started......does anyone have a base map for this engine???
thanks
Hoffman5982
Car: '95 sr20det 240sx
wait, so you convered it BEFORE you had everything you need? smart move
veloce240
Actually I converted it because I was told it was easier to tune that way. and if anyone has a base map of a stock rb20det I could easily change it to map and have it work......does someone have a aem ems series 2 base map for an rb20??? I would really appreciate it
thanks
kouki munster
Car: 97 base 240
Check aem's website, also if it was the plug and play model it should have come with some sort of base map that is good enough to get it to fire up. If not, set the timing to about 15* btdc and start adding fuel until it fires up and keep a close eye on your wide-band o2.
Edit: Make sure you have the proper calibrations for all of your sensors to.
