s13_240_rb20 »
https://forums.nicoclub.com/s13-240-rb20-u87143.html
Fri Nov 20, 2009 1:58 am
Nevermind. Luckily, I figured it out by trial and error without frying my alternator.
On the RB alternator, the big white wire on the 2-wire plug is connected to my battery. And the small white/red wire is connected to the signal wire from the CHG lightbulb in the gauge cluster.
For future reference, there is a rectangular plug by the battery ON A NISSAN HARDBODY PICKUP and it has 4 wires to it. Since mine was an engine swap, my wiring stopped at the female plug. I ran the small white/red wire from the alternator plug to the yellow/black wire (the CHG signal wire) on the female side plug. That yellow/black wire measured about 6 volts and when connected to the white/red alternator wire, my voltmeter connected at the battery jumped up to 15v at idle.
As I have previously found out, connected the white/red wire to 12v caused the voltmeter (at the battery) to jump to 17v and the engine would stall in a few seconds unless I disconnected that white/red wire from 12v.
Lesson: 12v on the white/red causes overcharge?? 6v on the white/red causes 15v charging (which is good I'm pretty sure).
--TJ
