but no welding, something a simple dremel could take care of?S13 240SX wrote:hey guys...
jus to let ya know this. When Acecool is saying cutting the top bolt.. he means by taking the alt bracket off, and trimming or cutting the upper bolt hole out of the upper bracket, becasue doing that, this will allow you to get more of a downward angle when re-installing the bracket back on, and letting the ka24e alt line up to bolt in.
Modified by S13 240SX at 11:02 PM 1/21/2008
I wonder if the same would be true with Quest internals... Something to ponder...240luvr wrote:Kid that had my motor before me took the internals out of a KA alternator and put them in the RB's housing, works fine, never had a problem.
a little searching would get ya the answer you're looking for....no...the quest alternator is larger then the rb alti so it's internals will not fit inside a smaller housingjohnny butt wrote:before I dropped the RB25 into my S13 I had my starter and alternator rebuilt by my friend with misc. parts.
Both (starter & alternator) were replaced with some type of mitsubishi parts.
I think the housing is really the only thing different between these alternators.
I would be interested in seeing if the Quest alternator guts would fit inside the RB25 housing.
