So my biggest complaint about the performance of this swap is the top end of the rpms in each gear.
In 1st, I can reach around 25mph at 5800 rpms
In 2nd, I can reach around 40ish at 4400
In 3rd, I can reach around 65mph at 4000
In 4th, I can reach around 70ish at 4000 (YES>>> ONLY 70ish)
In 5th, I can reach around 80ish at 3000, using WOT. If I stay WOT for a mile, I sometimes reach 90ish at 3500.
As you can see, this is no longer a fun vehicle. Keep this in mind and read the chart above again: In my 240sx, I could redline EVERY gear @ 7500, but I never pushed all the way to 5th gear redline...too fast...over 150ish at 6000rpms.
I know nothing about gear ratio's except what I just typed here, and what I just read on the net:
determined by driveshaft turns / 1 turn of the rear wheels (understood)
"HF37 axle is only used in weenie 2wd Frontiers" (according to the net, but my hardbody's doorjam disagrees)
What complications come up when using an auto axle with hi-power 5sp transmissions? What can you tell me from what I have explained? I want my power and speed back
--TJ
