RB20det & 300zx MAF The Same???
side waz
Car: 1990 R32 Nissan Skyline GTS-T Type M, RB20det. Previous car 1991 240sx SE fastback, KA-T.
Hey guys.
Well we know it's sometimes hard to find a 300zx TT MAF but I'm wondering if the RB20det MAF will work and if it's the same as the Z32?
They look the exact same which you can see. Here's the link to one off of Ebay,http://cgi.ebay.com/ebaymotors...ZWD1V
I know they may not be EXACTLY the same or have the same IN/OUT but can we use them? I have access to these no prob so I want to know if I should grab it.
As well would ANY Skyline MAF work? I know the RB26dett MAF's can handle insane boost with no issues like the Z32 but for now how good is the rb20?
Well if anyone can shed some light on this, 100%, that would be great. Getting my new turbo, boost controller and up'n the boost so I want to upgrade my stock KA maf.
Thanks guys.
Easy
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
No it is not the same the rb20 is the same as the series 1 rb25 with 5 pins and series 2 has 3 pins but as far as power the rb is only good for 350 hp
side waz
sean8564 wrote:No it is not the same the rb20 is the same as the series 1 rb25 with 5 pins and series 2 has 3 pins but as far as power the rb is only good for 350 hp
Not saying your wrong man but, can anyone else confirm or deny this?
Also has anyone here used a Skyline MAF for there ka-t set up? I'd really like some clerification here as I can get one of these for nothing and I want to know if I can use. Oh, and if so is there anywhere I can score a wire diagram to do?
Thanks guys.
sean8564
1993 Nissan Silvia
I run a RB25 in my s-13 set up check out my website http://www.ga240sx.comand here is the car zerothread?id=136189I also import vehicals from Japan zerothread?id=142829http://forums.nicoc ... ?id=146001
sean8564
1993 Nissan Silvia
IT ALSO SAYS IN THE AUCTION
Ebay wrote:These MAFS measure 80mm in diameter and utilize 5 pins. The part number on these units is 22680 02U00 A36-000 J60 and are capable of just over 300hp.
side waz
Thanks man.
I really was'nt saying your wrong or anything so please don't think that. Just wanted to hear some other thoughts but you really seem to know your sh_t.
Now I only plan for this motor to make 300ish rwhp so this MAF will work then.
My next question is do you know how to wire it up and if so, do you have any diargrams or "how to's"?
sean8564
1993 Nissan Silvia
I have the info i will send you tommarow
side waz
sean8564 wrote:I have the info i will send you tommarow
Hey man.
By any chance do you have that info?
Thanks.
sean8564
1993 Nissan Silvia
should be like this A- nothingB- signal outC- chassis groundD - sensor groundE- 12V powerF - nothing
side waz
sean8564 wrote:should be like this A- nothingB- signal outC- chassis groundD - sensor groundE- 12V powerF - nothing
Sorry man but I'm a complete newb when it come to electronics. I don't like it to much.
Could you explain in more detail? Just pretend I'm a 6 year child. LOL
hannibal
Car: Red Line to Glenmont
The RB20 MAFs plug should have 6 different pins on it. Thats what the A-F represent.
The stock plug on your stock MAF should have 4 wires coming into it.
First, identify what each of those four wires are using the FSM (and maybe double checking with a voltmeter). Once you know which wire is the signal out (0-5V), grounds, and 12V, just connect them to the pins sean mentioned.
I just noticed the RB20 only has 5 pins, while the Z32 has 6. Maybe someone can tell you how the RB20 MAF is wired (try the RB forum). But the concept I mentioned still applies...
hnugen
what do you do with the temp sensor when you replace it with another MAFS? It's the 2 wire that goes into the intake box.
