mello88 »
https://forums.nicoclub.com/mello88-u18450.html
Wed Jun 18, 2008 10:12 am
I would pressure check like this... Bolt it to the motor, use RTV and/or your gaskets for the manifolds and your TB. Plug all the vac ports, and seal the TB using a 2.25/2.5" silicone coupler with a aerosol can clamped in (or skip the TB and make a TB blockoff plate, see next paragraph). Use one of your vac ports and your air compressor and a modified leakdown tester/regulator/etc to pressurize the manifold. Use soapy water to spray down all the sealing points and watch for bubbles. Alternatively, make a quick blockoff plate with holes for the lower manifold bolts, that way you can pressure check it off the motor. I would test to ~1.5-2 times the boost you anticipate running, 25-35psi.
When I pressure checked my oem 20 manifold I bolted everything up except the TB. I made a blockoff plate out of 1/2" MDF with a thick RTV ring on it where it touches the mani... I let the RTV cure then bolted it on where the TB would usually go. Made sure everything was plugged off except one of the vac ports, and pressurized with my compressor + leak down tester to ~30psi. Used soapy water to find leaks/bubbles, all I found was the stock (porus) paper gasket leaks slightly under boost (used RTV instead, now it holds 30psi with 0 leaks).
GO!
edit: ps please send me an email about the other mani. (jo el me ll o at gm ail d ot c om)
