rb20 wont start need help here's "video"
preston240sx
Car: Nissan 240SX S13
Ok so i looked at other peoples video's and mine kinda seems the sameonly i should'nt be having this problem i payed 300 buck to have my harness done and everything seems like its working except it wont fire the ecu light is on so its getting power .... here the video lemme know if you can help also i had to cut out an alarm system and there are some loose wires maybe you can help with that too .. thx
http://www.youtube.com/watch?v=VT7sGz3oTYY
thx hopefully you have an idea of whats goingon
S13 240SX
Car: 93 Mazda Miata
dude you have no vaccum lines hooked up!!!!!!
there's no intercooler piping which tells me and thinks you have no mafs plugged or it is plugged but its just laying there..
hook the crap up.
Zippy69
Car: 1993 240sx coupe
Do you have spark at your plugs? Have you set your timing from tdc? Check your voltage at coil.Start at your plugs and work your way back. Plugs-wires-coil-voltage to coilIt sounded like zero spark to me on the vid. GL
preston240sx
yeah i know i dont have some vacumm lines hoooked up all im looking for as of now is to get it to wanna start ...
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
I like your camera.
S13 240SX
Car: 93 Mazda Miata
hook it all up and start and then come back if it dont work and then if i t dont work then check your plugs.
Carl H
are your fuel lines reversed?
preston240sx
i dont think they are ... how would i check ? loli dont think i did ...
onepuff
The plugs for the o2 sensor and one that goes to the coils i believe are the same type. I had mine switched up and it would just crank. Got them switched back the right way and it fired right up. Maybe check that.
S13 240SX
Car: 93 Mazda Miata
yeah i would check those fuel lines and hook the freaking vac lines up and ic pipes!!!!!!!
digzsublime
Car: 95 S14 w/ LS1.
preston240sx wrote:i dont think they are ... how would i check ? loli dont think i did ...
Edit: I'm an idiot. Corrected.
Fuel line coming out of the top of the fuel filter should go to the lower line on the front of the manifold.
The other line ( fuel return ) should be hooked up to the fuel pressure regulator which is the top line on the front of the manifold.
Modified by digzsublime at 3:40 AM 1/7/2008
preston240sx
fuel lines are fine but i'll check the o2 plug after work tomarrow i have 16 days off coming up soon i should be able to get it going by then i'll try and get a better video and pictures tomarrow
preston240sx
well i checked today and i have spark and i can smell gas ... but how would i check and see if the injector's are working ...seems like maybe they are'nt firing
preston240sx
any one know what plugs these are ?i cant find anywhere for them to connect ? are they just left overs or what ?
also i dont think im getting any power to my injectors how would i check that ?
