rb20 wont start messed with the tps sensor
homesivan11
Car: 1989 Nissan 240sx with a RB20DET swap
I have a rb20 was running good, but had a high idle problem replaced the tps with a new q45 and wired it in, but know it wont start up, no codes fuel pump primes spark at all 6 will not start with starting fuel,injectors are getting battery voltage at both ends, Is this my problem? i looked up information and it says one wire is battery voltage and the other is grounded from the ecu?
did anyone else have this problem?
homesivan11
got the car started today, after tracing every wire from the tps sensor to the computer, and found that two wire were cut some where replaced the wires and after a couple tries the car start up......
