nick6052 »
https://forums.nicoclub.com/nick6052-u60925.html
Thu Feb 14, 2008 12:06 am
Hey, I have a question..... Was your car automatic before you put the engine in? Mine was auto, and when I did the manual swap for the rb20, mine wouldnt crank either.... had power, just no crank. It turns out there is a saftey switch you have to bypass at the fuse box under the hood. It has two thick wires that are not used anymore. Just connect them together and you should be good to go. Just test everything to make sure you have the right plug. Hope this helps.
Nick
