rb20 wont idle?stalls
lexrob
Car: s14 95'
Ran great for what is now 4 days messed with cas got missing to go away. Ran perfect purred like a kitten a little high at 900. Then today stopped at a light and it just died. Started it back up ran for like a sec then put pu dead. ..Start up give a little throttle and keep revin holdin e brake LOL. Take off RUNS Perfect just wont idle at all.??
Im stumped.
Checked cas, AAC, maf, plugs, GN coil....fuel psi good at idle temp., voltage....
Tried pulling off boost vac line to raise it. Then tried pullin plug of AAC NOTHING.
Any ideas guys im really lost on this one cant believe it was perfect for 4 days and now takes a dump.
dtowngoalie
Sounds like you blew off an intercooler pipe to me, since you were driving and all while it happened.
lexrob
Car: s14 95'
It was pushes boost normal checked anyway... non that are visible all clamps nice and tight.
Im going to attempt to pull codes out of it fsm makes it sound really confusing.
MATTs14
Car: Red 1995 Nissan 240sx
you still have that maf that i gave you that has the hole in it?? That could be a problem
lexrob
Car: s14 95'
Ended up being sumthing with the maf. Rewired cleaned and good to go? Now its kind of eratic but whatever!
