Sil240 »
https://forums.nicoclub.com/sil240-u6842.html
Thu May 21, 2009 6:45 am
If you welded the flapper 3/4 of the way I don't think thats the problem. Unless the weld didn't penetrate and with the heat just fell apart.
Do you have a laser temp gauge?If so take a reading of the downpipe at idle with the car running for a bit, then take a reading of the wastegate dump tube.
It should be a bit lower.If your Dump tube is re-routed back into the exhaust it might not read any difference.
But.....Maybe you have the boost controller hooked up wrong.Why don't you hook the WG directly to the Intake manifold/vacuum source.
That way you can eliminate complications of the BC.
Also maybe the Diaprham in you WG is ripped.If so then your exhaust pressure would be just pushing the valve open.
Blow in the C port (or what ever port your using) and make sure it holds pressure.If it doesn't you've found your problem.
